PyroElectro.com Forum Index PyroElectro.com
Build what you want, Be the pyro you are.
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
The Autonomous Drifter
Post new topic   Reply to topic    PyroElectro.com Forum Index -> Projects
View previous topic :: View next topic
Author Message
PostPosted: Thu Feb 28, 2008 11:15 pm    Post subject: The Autonomous Drifter Reply with quote
Quote:
The autonomous drifter is an rc car with a modified transmitter that allows a computer to control it via the serial port. It has both manual and autonomous control using the keyboard.
Link
Back to top
View user's profile Send private message Send e-mail AIM Address MSN Messenger
simonwai
PostPosted: Sun Jun 01, 2008 7:11 am    Post subject: drifter problem Reply with quote
hi
i read that drifter project
about the vb script, i copied and pasted in a notepad and saved it correctly
and double clicked on it , but nothing happened but why?
also i wanna use hyperterminal to send date to the serial port
but what should I send to remote the car?
Sorry I am not good in electronics, but I really want to learn more
Please clear my doubts
Thanks so much in advance
Back to top
PostPosted: Mon Jun 02, 2008 5:02 pm    Post subject: Reply with quote
Hi Simonwai,
If you've saved it correctly "test.vbs" then the icon should change from a notepad (txt) file:
to a script file:
I only tested on Windows XP, so I don't know if it'll work on other versions.
You can use hyper terminal to send data serially but the setup takes a bit longer than with the program I offered. I'd recommend using mine over hyper terminal.
If you have more questions, just ask Exclamation
Very Happy
Back to top
nite
PostPosted: Fri Jun 06, 2008 9:40 pm    Post subject: Reply with quote
nice project. i made something similar with a pc, parallel output, relais and a dos based c programm back in the school
Back to top
Captain_Crunch
PostPosted: Wed Jun 25, 2008 7:52 am    Post subject: Reply with quote
That is very cool!
Back to top
PostPosted: Wed Jun 25, 2008 7:46 pm    Post subject: Reply with quote
Very Happy not terribly hard to make either.
Back to top
jsn8610
PostPosted: Tue Aug 18, 2009 8:10 am    Post subject: Reply with quote
Hi...i'm quite confusing...
i'm using window xp
after i save as "my_script.vbs"..i double click it, there's nothing happen..
so i wonder..what is the function for "my_script.vbs"?
What is the function for <good_terminal.exe> software after i install?
izit it got relate to "my_script.vbs"?
Back to top
jsn8610
PostPosted: Tue Aug 18, 2009 8:11 am    Post subject: Re: The Autonomous Drifter Reply with quote
i'm using window xp
Laughing
any information given are very helpful for me.
Thanks!!
Back to top
PostPosted: Wed Sep 23, 2009 5:06 am    Post subject: Reply with quote
The .vbs file was simply meant to press keyboard keys programmatically into the good_terminal.exe program. This would then control the car with a premade selection of how it should drive. No software/hardware drivers necessary.
Back to top
Display posts from previous:
Post new topic   Reply to topic    PyroElectro.com Forum Index -> Projects All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
