PyroElectro.com Forum Index PyroElectro.com
Build what you want, Be the pyro you are.
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
The Music Equalizer Display
Post new topic   Reply to topic    PyroElectro.com Forum Index -> Tutorials
View previous topic :: View next topic
Author Message
PostPosted: Tue Mar 25, 2008 9:39 pm    Post subject: The Music Equalizer Display Reply with quote
The Music Equalizer Display Tutorial Write-up
Quote:
If you've ever used a music playing utility on a pc you'll notice they always have a cool little display of either the audio frequency spectrum or the actual audio amplitude wave. The Music Equalizer Display created in this tutorial outputs the latter using a standard 10 LED bar.<
Back to top
View user's profile Send private message Send e-mail AIM Address MSN Messenger
rverdeil
PostPosted: Fri Apr 25, 2008 5:52 pm    Post subject: how do i make this bigger? Reply with quote
i want to take the same concept and use a row of about 50 led lights as the visualizer. how and where do i start?
Back to top
PostPosted: Sat Apr 26, 2008 1:16 am    Post subject: Reply with quote
Hey Rverdeil,
The only real difference between lighting up 10 lights & 50 lights will be with the A/D's. The ADC is 10-bit so the highest value it can be is 1023.
So instead of divided 1023/10 and having 10 increments of 102.3 for the full scale of the ADC, you'd divide 1023/50 and each led would represent an increase of 20.46 in the ADC value. Very Happy
Exclamation Hopefully that makes sense. Just let me know if it doesn't.
Back to top
elrunethe2nd
PostPosted: Tue Jun 01, 2010 6:06 pm    Post subject: Equalizer Headphones Reply with quote
This is going to seem like a bit of a necropost, but oh well.
I have a few questions from an electrical engineering newbie.
First, could this setup be powered from the same power that heads to the headphones? Is that a realistic idea? Even fullsize headphones?
My thought was about mounting a row of these to the sides of a pair of full size headphones so that you had an equalizer on the exterior. (In the image of a traditional equalizer similar to that on those shirts floating around). I'm sure that if required, fitting batteries wouldn't be too big a deal (you could maybe hide it in some of the soft lining near the edge?), but it would be easier without.
I realize this is pure eyecandy and probably a bit of a power hog, yet I am still intrigued by the idea.
Thanks in advance; any thoughts appreciated.
(I did this here as there are VERY few articles which discuss this, and yours does it the best!)
Back to top
PostPosted: Wed Jun 02, 2010 2:40 am    Post subject: Reply with quote
The power coming out of any CD or MP3 player is not enough to really power multiple LEDs. An external power source would be necessary, these small button batteries could do the trick.
But your idea is definitely feasible. You will have to modify the headphones and use a smaller PIC so that the package isn't too big.
Back to top
elrunethe2nd
PostPosted: Wed Jun 02, 2010 5:58 am    Post subject: Reply with quote
ThePyroElectro wrote:
The power coming out of any CD or MP3 player is not enough to really power multiple LEDs. An external power source would be necessary, these small could do the trick.
Those batteries would be easy to conceal inside a pair of bulky enough headphones. That's great. Very Happy
The PIC you've suggested initially is 5cm long according to the manufacturer. That isn't too bad, but it is on the large side as you said. What would you suggest for a smaller one? Would any PIC be suitable? (Eg: a PIC16F684?)
Also, if I wanted to have five of those LED's in a row to resemble a more traditional equalizer (all with the same output reading), would the power requirement be significantly higher?
Back to top
Display posts from previous:
Post new topic   Reply to topic    PyroElectro.com Forum Index -> Tutorials All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
